First off, sorry if this is the wrong category, please move it if it is.
Alright so a while ago I managed to score 2 arcade machines for $50. Quite a sweet deal, especially considering I'm throwing my grandpa's old pc in one of them. I bought some new (used old parts ) parts for it for cheap and got it running really well, considering. Then the mobo died. I bought another one to the same specs on Ebay and plugged it all in. No display, not even a POST, with the onboard port OR the graphics card. Motherboard boots up, fans go on but nothing else really. The mobo speaker got crushed somehow so I can't tell if it's beeping or not. I've tried it with practically all combinations of the old and new parts and still nothing. Here's the parts:
Mobo: Old - PC Chips M825 v7.1A
(http://www.baber.com/motherboards/pcchips/pcchips_socket_a/pcchips_m825lu_v7.1a.htm)
New -Gigabyte GA-7VM400M
(http://www.cpu-upgrade.com/mb-Gigabyte/GA-7VM400M%28Rev_1.x%29.html)
(http://www.gigabyte.com/products/product-page.aspx?pid=1670#sp)
CPU: Old - Amd Duron 1300
(http://www.cpu-world.com/CPUs/K7/AMD-Duron%201300%20-%20DHD1300AMT1B.html)
New - AMD Sempron 3300+
(http://www.cpu-world.com/CPUs/K7/AMD-Sempron%203300%2B%20-%20SDA3300DKV4E.html)
RAM: Old - 1x 256 MB ValuRAM KVR266X64C25
New - 1GB (2x 512 MB) DDR 266 PC2100 (ATP?) AG64L64C8SQB0S
GPU: nVidia Geforce FX 5900 XT 128MB AGP 8x
PSU: Maxpower PX-350W Ver. 2.03
I noticed on the old motherboard I connected the 20-pin wide connector, same as the new one, but the old one also connected a 4 pin connector. The new one doesn't have that 4 pin slot. Does that make a difference?
I tried to be as detailed as I could, but please tell me if you need more info.
Also I should mention the Power and "MSG" lights both stay solid when turned on, no blinking or anything.
http://i228.photobucket.com/albums/ee43/SonicBlaze425/Arcade%20Cabinets/Arcade%20Machine%20compie/080712_11182.jpg
