6870 needs 2 6 pin power cables, but PSU only has 1 6 pin power cable
- Only 1 6+2 pin power cable - Forum
- I'm trying to power my gtx680 which requires a 6 pin and 8 pin. I have a cable which is a 6 pin at the psu that splits into 2x - Forum
- Power Supply does not have enough 6pin cables for 2 cards. Need help. - Forum
- I'm in thought of buying a HIS Radeon HD 6770,but it needs 6 pin PCI express power cable but i have a 4 pin peripheral connec - Forum
- [HELP] Graphics Card Requires 2 x 6 PIN to 4 PIN Power Cable. What To Do? - Forum
- Wondering about new 8 to 2 6+2 pin power cables Forum
- SolvedGTX 650 Ti Boost DCU-OC2, can it run without 6-Pin power cable? Forum
- SolvedNeed 2x 6 pin cabels for my videocard, my PSU only have 1 6+2 pin cabel. Should I buy new PSU or additional cabel? Forum
- can i turn a sata 2 cable into a pcie 6pin power cable for a gpu? Forum
- My power supply only has 1x6+2 pin PCI-E connector and i want to put a 7870 in my pc Forum
- PCI-E 6-pin to 2-Molex Power Y-Adapter Cable Keeps burning Forum
- Solved500w PSU has only 2 PCI-E 6 pin, but I need 1 PCI-E 8 pin for XFX DD HD 7950. Help? Forum
- 8 pin pcie power adaptor for 6 pin pcie only psu-need advice Forum
- CPU power slot needs 4 pin but my PSU has 6+2 pin.? Forum
- Recom PSU needs 2 x 6pin PCI power adapter Forum
- SolvedConnecting a PSU which only accepts 6 pin cables to a Sata hard drive? Forum
- SolvedUpgraded GPU that Needs 2x6-pin PCI E But Only Have 1 6-Pin! What should I do?! Forum
- SolvedDoes anyone know if this card requires one or two 6 pin power cables? Forum
- SolvedMy gpu came with 2x cables which were 2x6pin going into 1x 8 pin. In the manual it showed that I could either do that or use Forum
- SolvedMy power supply has two cables: CPU1 which is a 4+4 pin, and CPU2 which is 8 pin. Does it matter which I cable I connect? Forum
- More resources
