like the title says
going to be buying a noctua DH-14 or Thermaltake Frio , wondering if it would fit in an Antec One Hundred Case. Also i'll be using it on the Intel DP55KG Extreme Series Motherboard
Here are the dimensions of the case :
- 480.5 mm (H) x 197.5 mm (W) x 477 mm (D)
- 18.9" (H) x 7.8" (W) x 18.8" (D)
# Package Dimensions
- 558 mm (H) x 270 mm (W) x 555 mm (D)
- 2.0" (H) x 10.6" (W) x 21.9" (D)
http://www.antec.com/Believe_it/product3.php?id=MjU1MQ==
so yea , hoping someone can help me out before my purchase!
thanks
thanks
