EXtreme power plus 550w capable of powering an Xtreme 5850?
Related ressources
- Is Cooler Master eXtreme Power Plus 550W good enough for HD5770 - Forum
- EVGA GTX 670 FTW on eXtreme Power Plus 500W - Forum
- Suggest a graphic card for Xtreme Brand 400 Watt Power Supply - Forum
- Crossfire 5850 + 5850 Xtreme - Forum
- Cooler Master eXtreme Power Plus 500W - Forum
Related ressources:
- ForumJust ordered my 5850 , is it defective or do I just need more power ?
- ForumQuiet, low power , three-monitor gaming rig
- ForumTwin Frozr II or Arctic cooling Accelero xtreme plus ? with GTX580
- ForumWhy do PSU calculator lie? Help!
- ForumWill Cooler master extreme power plus 600w support HD 6670 or HD 6750?
- ForumZ77 extreme 4, i5 3570K, 550w PSU = Which GPU?
- ForumAsus 660ti DCU2 SLI, 680 DCU2 TOP or 7970 Matrix
- Forum[Solved] 6870 needs 2 6 pin power cables, but PSU only has 1 6 pin power cable
- ForumPowercolor 5850 & Sapphire HD5850 Xtreme 1GB GDDR5
- ForumSapphire tech hd 5850: driver issue?
- Forum[Solved] Best pci-e low profile graphic card for dell-gx745 which can run with default po
- ForumGTX 460 vs GTX 560 Ti vs HD 5850/5830/6870
- Forum[Solved] Intel extreme graphics
- ForumHD 5770 power requirements ?
- ForumPower supply
- More resources
