Hi guys,
Got a question for you. I am going to be upgrading the graphics card in an older rig of mine soon, the specs are:
Athlon XP 3000+ 2.175GHz
Mobo: Gigabyte GA-7VM400M
RAM: 2x1GB Patriot DDR1 PC2700
GFX: (Currently GeForce 6200 AGP 8x)
PSU: Corsair 430CX Builder Series (dedicated single +12V rail @ 28Amps) But... only 1 leg of Molex connectors with 3 Standard Molex and 1 floppy all on the same cable.
Optical: Asus OEM DRW-1608P3S
Floppy Drive
HDDs: 320GB WD Caviar IDE HD and a 60GB Seagate Barracuda IDE Drive
OS: Windows XP Home Edition 32bit
My question is this... What graphics card can I buy that won't be totally bottle-necked by my CPU?
I was considering the 6800Ultra AGP as there are some nice refurbed ones on eBay right now for about $70USD. Only problem with this card is it takes two! Molex connectors. I was wondering since my PSU is short on Molex connectors, but has plenty of AMPs on the +12V Can I just plug in the two Female connectos of a single Molex Y-Splitter Cable to the GFX Card and the male end to a single point on my PSU?
This card seems like a hassle with the power connectors, or maybe it's simple like I thought (Single Y-Cable connection).
My other options are: An old standby of mine: the Radeon X850PRO... This card works well with my P4 3.0GHz rig with a similar config to the AMD rig (Win XP 2GB RAM Etc.) The performance from that rig is ... acceptable, but I'm looking for a tiny bit more if possible, and I hate to have so many computers with the same GFX card in them (Boring same hardware).
The other thing I was considering was the Radeon 4650 by Gigabyte... This card would definitely allow HD video playback which is a plus, and performance is sure to be better than my GeForce 6200... But the price is $80USD, so would I be better off going with the 6800Ultra for $70? The GF6 series was made to natively support the AGP slot, whereas the 4650 is more of a strange hybrid part with an PCI-E to AGP Bridge... Which tends to get hot.
Before you answer, please just consider the project at hand and know that I an doing this purely for fun and to revive an old rig... (my first "gaming" PC). I am trying to keep cost down as much as possible, but best performance for the build is the main objective. I know this rig is OLD (VERY OLD) and I know it's a "waste" of money... I just have a sentimental bond with the machine and want to see it run at its peak again
Originally it was a HP Pavilion 552 with a GeForce 4 Ti4200 (Which owned back in its day), but everything in it has been replaced including the motherboard, so it now just resembles the old configuration in spiritual form more than anything... lol
Well guys, which GFX card do you recommend?
Floppy Drive
