Hello and thank you for your advice. So I'll start with the build/parts i have in mind with the little knowledge I have on building a gaming pc. Some of these are taken from other threads on here and some are just by Newegg most reviews/best rated, etc.
CASE:
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower with USB 3.0
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $159.99
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $189.99
CPU:
MOBO:
GIGABYTE GA-Z68X-UD4-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX
ASRock Z68 PROFESSIONAL GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $249.99
GPUu:
OUT OF STOCK
MSI R6950 Twin Frozr II OC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $289.99
RAM:
PSU:
PC Power and Cooling Silencer 910W High Performance 80PLUS Silver SLI CrossFire ready Power Supply
CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $174.99
SSD:
Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $114.99
Plextor PX-M2 Series PX-128M2S 2.5" 128GB SATA III
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $218.99
HDD:
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $89.95
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $59.99
DISC DRIVE:
HEATSINK:
COOLER MASTER V6 GT RR-V6GT-22PK-R1
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $59.04
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $29.99
Second I play mmorpg's (AION mostly) and most likely thats only type of games I'll be playing, if that matters at all
The questions I have are as follows....This build to much for Aion? I'm thinking I could get the i5 or something even chearper and save some cash. Which leads me to my next question if i were to get a lesser cpu/mobo and upgrade in a few years when newer mmorpgs come out how will the rest of the components perform? From what I've gathered so far the major upgrades are cpu mobo and gpu unless somethin else breaks. So basically could i go with a cheaper build and save several hundread bucks to upgrade cpu/mobo/gpu or whatever is recommended in 3+ years.
And since i dont really know much whats neccessary to spend lots on on like ive seen people say the cheaper gskill ram is fine for 2000 build and then on high end intel thread people have gskill ram thats $30+ compared.
Sorry if these questions are already answered on a sticky. Im just a super noob and dont have to much time to research this stuff. and sorry if my thoughts are jumbled a little unsure how to ask these questions.
also if theres recommendations for different parts im totally open to that. but id like to stick with intel and reliable brands/parts. :]
Thanks for your time and help
