New Build Problems
I recently put together a HTPC
with the mobo
MSI 880GM-E35 Socket AM3 880G mATX AMD Motherboard
cpu: amd phenomii x4 840 3.2 ghz
ram: 4gigs of 1333 kingston ram
psu: antech earthwatt 380 80+
case: silverstone GD05 case
optical: sony optical
put everything together, fired it up, installed windows 7 professional
and everythigns running but for some reason the HDMI port doesn't work
i tried to hook it up to my samsung tv as well as my asus monitor, but both of them say no signal when i run it through the HDMI, im pretty sure the cable isn't faulty because ive hooked it up to my laptop and it worked
the vga works but the hdmi doesn't work
what is wrong?
is it the driver? ive updated the drivers and the bios as well
thanks for the help
1 answer Last reply
More about build problems
  1. You are only using the HDMI not using another connection when you are trying this?
New Build Systems
