Hey folks, this is going to be my first apparition onto this forum I am just asking for people's suggestions... *Should I change anything?* or *Should I upgrade something?*
What I am looking for at the momment is a System that's going to be strong enough for Witcher 2 ran on max graphics to give you an idea of what im looking for as of gaming wise haha. Also looking for maximum speed and smoothness of control in the game so... Max FPS, Max Resolution, (might use 2 24'' Samsung LED 1080P screens)
Max Graphic, if you want to add anything you're free to go I accept any suggestion anyhow... I did some reseach afterall so that I am prepared to hear all kinds of suggestions and I will be posting every links of every item I am about to buy to build my first complet System!
Chassis: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119197
Motherboard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130565
Graphic: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127594
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103894
Powersupply: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139023
Solid State Drive: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820227728
Hard Drive: http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136769
Memory: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231402
Blue-Ray Drive: http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151222
As far as OverClocking! Yes indeed I am building this so that I can exploit the OC as much as possible to make my computer much faster reason why I choose the Graphic Card and the Memory (memory due to its Cas and Timing) (graphic card because of the high Core Clock and the high Memory Clock)... and yes I am going to use Window 7 64-bit Premium Edition... for maximum Memory GB and speed...
Thanks a lot to ya'll who will be kind enough to help me out with this computer build and to tell me if its built right or wrong!
Cheers, Alex
Cheers, Alex
