Hi Folks, I sure could use a little help here. I just installed a new Z77 extreme4 and i7 2600K and things were going fine. I booted to the UEFI, made some changes I knew I would need to get the Hard Drive to boot to windows 7 64 bit OS, and then saved and exited. (I set the Sata to IDE).
The program booted to my OS, but in what appears to be Safe Mode or at least it looks like that. All the desktop Icons are huge like it didn't use my GPU, (ATI HD 5770). But I expected that and it went on to find some drivers... no problem. But I had an ASUS M5A97 EVO and AI SUITE II with an AMD 965BE which I replaced with this stuff.
One problem was that I forgot to uninstall the AI Suite II so it was trying start and then a box opened and said it couldn't. OK, so then it installed some drivers and when done, said to restart. So before I did I tried to uninstall the AISuite but it wouldn't even respond to my attempt. I’m going to have to install a ‘special’ program to get rid of it but for now, I’ll try to rename the .exe if I can.
So I clicked shutdown but the computer rebooted and gave a message that windows had recovered from an unexpected shutdown. Then I said boot normally and it opened to my Desktop but again, all the icons were huge. It then said it was installing drivers and included the Main HD and my Graphics card in the list of about 6 items.
But after almost a half hour it failed the driver update for both the Hard Drive and the Graphics Card! One driver was loaded successfully, (a USB tool or something, I forget), but the others were still trying to load when I decided it had been long enough, (40-50minutes at that point), and hit the "reset" button. Then I checked to make sure my GPU was active in the UEFI and double checked a few things.
After that I saved and exited and told it to shutdown when it had got to my OS sign in screen. It took 20 minutes to finally shutdown and then restarted immediately! I'm pretty sure it has to do with some settings but I don't know which ones.
The Bios version is P1.4 15B. Does anyone know what I should try?
Thanks, Rich
Thanks, Rich
