Hi guys,
Earlier this week I notice when I am using my headsets through the front panel audio jack, I have lost the right audio.
The case I have is the Rosewill Challenger.
It started several months ago when the right audio would not work for sometimes, but then it works for a while so I ignored it... but now the right channel is completely gone.
The back panel audio jack is working fine.
I am wondering if there is anything I should check, or how should I go about fixing it (may be some place to get replacement parts?)
Thank you very much!
