Solved
3pin Power led but 2 pin motherboard
August 10, 2012 7:13:30 AM
so all the other pins fit nicely but I am left with a 3 pin power led but only 2 pins for it
http://www.techpowerup.com/reviews/ASRock/939SLI32-eSAT...
all the pins are full besides top two left (and bottom right)
More about : 3pin power led pin motherboard
Best solution
August 10, 2012 10:36:33 AM
Your case has 3pin power LED? I have never seen a computer case which has 3 pin for power LED.
If you are sure...can you just use 2 pin (left 1 pin un-used)?
August 12, 2012 1:12:56 AM
yes I am sure I just pulled the wire out and stuck in the empty space next to it and it worked.
m
l
September 6, 2012 11:51:30 PM
Best answer selected by austinedwards7.
m
l
