Intelligent Energy Saver problems in Z77
i'm using ASrock Z77 extreme4 with a intel 3550 for last 1 week..just today i went to the bios and set everything to default..now when stressing the cpu with IBT temps are reaching 67C with CM hyper EVO..i went to AXTU and i saw Vcore is 1.4/1.2 and when i turned IES off it returned to .998...
i've manually set:
VCCSA ----- 0.925
VTT --------- 1.076
CPU PLL---- 1.783
CPU PCH--- 1.059
Vcore------- 0.940
they fluctuate over time
My question is how do i turn off IES permanently?
...i turned it off once..but when i restarted it was turned on
1 answer Last reply
More about intelligent energy saver problems
  1. are the above voltage settings okay...which temps should be fine???
ASRock CPUs Motherboards
