Here is my original thread :
http://www.tomshardware.com/forum/299856-30-computer-booting-split-second-flash-power
Basically what happened was that one night my computer turned off and would not turn back on. Reset the power cord just gave a brief second of power before not doing anything until the power cord was reset again. I tested my PSU (Corsair HX620) with the paper clip trick and it did turn on (had it run my fan and hooked up my HDD to another computer with it). I thought it might be a blown PSU as with some of the posts in my other thread hinting at that as well I picked up another PSU (Corsair GS700).
When I plugged up my new PSU, the computer got power. The fans turned on, my LEDs turned on and everything seemed to be on...but my motherboard showed code 00 and would not boot. Just on a whim, I hooked my old PSU back up and it did the same thing as my new PSU. I am currently finishing the RMA for my motherboard and what I'm wondering is this :
Do I hook my old PSU back up(it started running the computer just like the new one when I hooked it back up last) or do I stay with the new one.
So I'm wondering...is it safe to hook the old PSU back and use it in my computer...or should I switch? I figured if the PSU was blown or caused damage it would not have turned the computer on at all later on.
