Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Need Advice - X58, i7, DDR3 system
Forum Systems : New Build Need Advice - X58, i7, DDR3 system
Approximate Purchase Date: Near future (Couple of months away)
Budget Range: $1,000 AUD
System Usage from Most to Least Important: Gaming, video editing/rendering, internet use, movies
Parts Not Required: Keyboard, mouse, speakers
Preferred Website(s) for Parts: www.ebay.com.au (AUSTRALIAN)
Country of Origin: Australia
Parts Preferences: Intel, GSKILL for RAM, Corsair for PSU, 10K RPM drive, cheap but overclockable i7, fast DDR5 GFX
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: A good cooling case that doesn't need all the flashing lights and stuff, just good airflow.
So far, I have thought up -
CPU –
Intel Core i7-920 Quad-Core Desktop CPU 2.66GHz
MOTHERBOARD –
ASRock X58-EXTREME, DDR3, LGA1366, SLi Support
RAM –
GSkill DDR3-1333, 6GB, Triple Channel, CL9
HARD DRIVES –
Seagate Barracuda ES 500GB 3.5" Hard Disk Drive SATA-2 – Windows
Western Digital 2TB Hard Drive Disk SATA2 – Games and game mods.
VIDEO CARD –
MSI nVidia GTX550 1GB DDR5 Graphic Card HDMI 192-Bit – No SLi/CF
SOUND CARD –
Creative Sound Blaster 5.1 Surround Sound Sound Card
POWER SUPPLY –
650W "Corsair" TX-750v2 ATX Power Supply – 80 PLUS Bronze Certified
CPU COOLING –
Coolermaster V6GT LGA1366 CPU Cooler
CASE –
Aerocool Vx-9 Pro LE BLK Mid Tower ATX Gaming PC Case
CASE FANS –
Stock (Stock fans already provide good airflow)
OPTICAL (CD/DVD) DRIVES –
1 DVD-RW Drive (Get from ABCD)
NETWORKING –
D-Link DWA-510 Wireless G PCI Adapter Network
Outside
MONITOR – Acer V243HQ 23” Wide LCD Monitor
KB & MOUSE – Microsoft keyboard/mouse combo
I'm looking to overclock to 3.3GHz and no more, will it all work when put together? Do I need to change stuff? Thanks a billion!
Best answer will be chosen
Reply to krimzon6
Hi there. In my opinion, I don't think X58 is the way to go right now. You could get a Core i5 2500K on a P67 board with about the same performance for a better price. And also, the GTX 550 is probably not the best card for the money my recommendation would be either the Radeon HD 5770/6770 or the HD 6790.
Here are some of the parts I think you should use:
CPU: Intel Core i5 2500K ~ $220
MB: Asus P8P67-M Pro ~ $150
GPU: Radeon HD 6790 ~ $150
RAM: Corsair Vengeance 8Gb 2x4Gb ~ $90
If you do change some parts, remember to check if everything else is compatible.
Hope this helped. :)
Message edited by Martin9630 on 08-13-2011 at 06:21:53 AM
Reply to Martin9630
There are 1991 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 38 minutes ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
