I know its long but it means alot to me if you atleast try to help
OK yesterday I got done building my computer I started it up "Reboot and Select Proper Boot Device" got through that error started installing windows 7 got a error in there tried again it installed because My HDD, SSD, or DVD drive didn't come with sata cable my mobo came with 2 when installing windows 7 i had my DVD drive and my ssd after that I switched it over to SSD and HDD got "Reboot and Select Proper Boot Device" again through opening and closing case and testing. I would turn it on and it would turn off then turn back on sometimes give me video and sometimes not, it was late gave up went to bed got up turned it on it worked i was using it got breakfast come back moved my mouse and turned off turned back on no video have not got it to work since. So i said screw it took out mobo and stuff just needed to boot to bios, didn't boot just black screen, cleared cmos nothing waited about 20 minutes came back turned it on Dr. Debug started to work again (before it would not) and turned off and back on nothing, got mad tried again and it worked!! got to bios, just for kicks and giggles turned off and back on it worked again.
So I guess my question is should I RMA? Do you think its faulty or just user error or will it work it out?
Any suggestions or help is welcome.
Specs:
i5-3570K
Asrock Z77 Extreme4
HAF X
Corsair TX650v2
Corsair H80
Corsair Vengeance 8GB 1600
OCZ Vertex 4 64GB
Western Digital 500GB Blue Caviar
ASUS DVD drive
ASUS Wireless Card
Specs:
i5-3570K
Asrock Z77 Extreme4
HAF X
Corsair TX650v2
Corsair H80
OCZ Vertex 4 64GB
ASUS DVD drive
ASUS Wireless Card
