Hi guys,
Some of the forums guys helps me last time for my old system, but at the end I decided to dump that system.
This is the config of new build PC. (Assembled yesterday by me, Its far my parents so its low end system)
Config:
I-ball cabinet
Crosair RAM - 2gb (1 dimm, 1333Mhz)
Mobo: Asus: P5G41T-MLX (G41 chipset)
Processor: E5700 (3 Ghz dual core)
SMPS: CX430 (Crosair 430 Watt)
HDD: ST340015A [40 GB Segate] (used from old system)
CD Drive: LG GCE 8526B (used from old system)
Information: My HDD and CD drive is old one so both are IDE connector, BUT my Motherboard has only single IDE connector.
So I used HDD as a master and CD drive as a slave on same IDE port and BIOS recognized perfectly which is master and which is slave.
Problem: When I start the system (CD drive with CD inserted) then its starts normally and works perfectly as long I can use.
When i try to start my system (CD drive without CD inserted ) then after POST its will restart again and again never reached at welcome screen.
When I start the system (with CD tray open) then also I works perfectly.
So problem of restart only When CD tray in and its without CD.
I connected the slave jumper on CD drive correctly.
Obervation: I tried to start system with CD drive and CD tray open and after computer starts normally then I close the CD tray without CD drive and it will restart as soon as CD tray gets in without CD.
Its strange problem for me, Why such behavior of CD drive. I am sure 430 Watt power supply is more than sufficient for this config.
MY CD Drive model is LG - GCE 8526B
Attention:
________
On this CD d rive there is marked Analog and Digital Audio, In my old system this CD drive used Analog Audio ( R G L) .
This Analog Audio (R G L) is connected with wire on old MOBO. But as in new MOBO that Analog Audio port is not there So I kept this unconnected. This connection is used for Audio only which we hear from CD directly.
So this connection does the cause of this problem I suppose.
Kindly help me out from this strange problem, If any more info needed So tell me.
Config:
I-ball cabinet
Attention:
________
