P8P67 PRO REV 3.1 8GB Dimm problem
Hi, Recently my P8P67 received some damage due to maintenance and apparently the 2 DIMM slots next to the CPU are not functional, wich is a bummer to me since I was running some old 4GB dimms there and I am too cheap to buy a new MB, does anyone have idea if the
Corsairs CMZ16GX3M2A1600C10 16GB set will work on the p8p67 since that would be a better solution than going and buying a new MB
3 answers Last reply
More about p8p67 dimm problem
  1. I looked at the QVL list for that board and there was no testing of 8gb dimms, either because they were rare at the time the board came out, or they dont work. On the plus side is that Corsair was listed many times, so if 8gb dimms are supported, yours will probably work.
    I would just run the 8gb you have now, or get a used board if $ is tight.
    "my P8P67 received some damage due to maintenance" plz elaborate :D
  2. Unless your board requires the 2 sticks to be in specific slots, they should work OK>
    Well, I took it out for maintenance and cleaning, Somehow, when I put it back inside, the 2 dimms are not working anymore. :/
Corsair CPUs DIMM Memory
