Hi guys! I was just wondering what temperature should be "fine" at load with the Sapphire radeon 5850. I stressed the GPU with OCCT and when I check CPUID Monitor to see the max temperature it shows about 60 - 75℃ for TMPIN0 and GPU 105 - 110℃. Its a little high the gpu temperature, isnt it? As I have done the test with stock clock 725/1000 and OC, when OC (800-900/1000) is applied GPU goes to +120℃ with fan at 100%. I have cleaned the dust from the graphic card and the case is open, ambient temperature is about 15℃. What could make the GPU to go so high at full load? By the way, Im using a CoolerMaster 500w EPP, could be because of this power supply?
Specs:
Asrock 890FX deluxe 3
Phenom II x6 1055T
4GB DDR3 1600MHZ CL9
WD 500GB BLUE
Sapphire Radeon 5850
Thanks.
Specs:
Phenom II x6 1055T
WD 500GB BLUE
Thanks.
