I think I am having some problem with processor fan... it never runs on full speed event though my processor temperature is going so high. I am using HWMonitor (also speedfan) to record temperatures and my temperature readings in normal are as follows:
HWMonitor further says:
And from the above reading I am guessing that my fan is running on 50% always and I think it is because it looks slow... Not really making any sound and you can feel any air blowing out of it if you put your hand in front of it..
I tried speedfan by my motherboard isn’t supported…
By BIOS also doesn’t have any such option all it has is:
Thank you.
But during high usage like while playing a game or something it hits around 80+, I tried cleaning the grill and fan and putting new thermal grease but didn’t help.Intel Core 2 Quad Q2800:
Core # 0: 65 c
Core # 1: 60 c
Core # 2: 59 c
Core # 3: 59 c
FANS PWM:
FANSWMIN0: 50%
My Specs are as follows:Advanced > Fan Control
o Processor Zone Response - Normal
o Processor Zone Damping – High
o Auto Fan Detection – Disable
o Fan Detection Error- Enable
Now I really want to know how to take my CPU temperature to normal again probably by making my fan to run at max speed, please help?Motherboard: Intel DG43NB [Version AAE34877-402]
CPU: Intel(R) Core(TM) 2 Quad CPU Q8200 @ 2.33GHz [Socket 775 LGA]
Thank you.
