Archived from groups: rec.photo.digital (More info?)
According to the Yahoo Canon 20D group, Canon has recently redesigned
the grip. Make sure your serial number is 6000 or higher before you buy
it. I know, that's hard to do online, if not impossible. This might be
one time to give your local camera dealer some business to help keep
him open.
>him open.
My local camera dealer is 120 miles away and is a day trip to get to
him. Out here in West Texas, we have lots of miles between places.
I'll see if the good folks and B&H can make sure I get a high serial
number.
Somone in the group just mentioned there might be a large red dot on
the redesigned ones. This is just what I read, can't vouch for either
the serial # or the red dot.
I'm planning on buying one too, but I'll wait a month or so to play it
safe.
John A. Stovall wrote:
> I've been thinking about one of these but it had several negative
> reviews on Amazon.
> Have any of you used it and how is the fit and stability of it. Or
> does in lose connectivity?
> "Les livres font les époques et les nations,
> commes les époques et les nations font les livres."
> _Mélanges littéraires_
> Jean-Jacques Ampère
> (1800-1864)
I have had mine on my camera almost all the time since I got it and have
not had a problem at all.
On 23 Mar 2005 11:12:09 -0800, in rec.photo.digital "Winston"
>him open.
Curious. I Nikon grip for the 5700/8700 was plagued with problems with the
latest high capacity NiMh AA batts which do not adhere to the IEEE
dimensional specs. Is this the problem with the Canon grip?
Ed Ruf Lifetime AMA# 344007 (Usenet@EdwardG.Ruf.com)
See images taken with my CP-990/5700 & D70 at
http://edwardgruf.com/Digital_Phot [...] index.html
On Wed, 23 Mar 2005 21:03:54 GMT, "Joseph Meehan"
>> reviews on Amazon.
>> Jean-Jacques Ampère
>> (1800-1864)
Must depend on when you got it. This thread shows there were problems
with them at least early on.
"Thanks for the American dream,
To vulgarize and to falsify until
the bare lies shine through.
Thanks for a country where
nobody's allowed to mind their
own business.
Thanks for the last and greatest
betrayal of the last and greatest
of human dreams."
"Thanksgiving Prayer"
William Burroughs
(1914-1997)
A) What's the serial number on it?
B) The problem usually surfaces when the grip is flexed such as when
you're carrying it by the grip with a large telephoto or zoom is
attached. It's probably just fine with lighter weight lenses.
buy
> it.
Where is the serial number located? It's not on the grip, and not on
the box.
There is a stamping on the plastic, 040881, but it isn't a serial
number.
There is an "EAN/JAN code" printed on the box, 4 96099 9243788, and the
UPC code.
<scharf.steven@gmail.com> wrote in message
news:1111685040.931838.58000@f14g2000cwb.googlegroups.com...
> buy
> > it.
> the box.
On the underside of the battery grip. Its stamped into the plate that
surrounds the tripod mount.
> reviews on Amazon.
Mine fits good. Bought it on Amazon last week. I don't know if it's the
redesigned one or not, but it certainly doesn't flex, so maybe it's the
new one (040881), which is greater than 6000, thoigh I find it
difficult to believe that they've made that many of these grips
already.
I noticed a little weirdness in the battery indicator when using the
grip. Once it showed the battery almost empty, even though it was fully
charged. I moved the battery to the other side of the grip and it
worked fine. Then I moved it back and it worked fine.
I certainly don't like this grip as much as the one for my EOS-5,
especially having to remove the battery compartment door to use the
grip. But I suppose that most people keep the grip on there all the
time.
>> reviews on Amazon.
>already.
The battery indicator problem seems to be one of many problems.
Learning it is there as resent as a model you bought last week, makes
me think Canon doesn't have it fixed.
On Wed, 23 Mar 2005 16:47:10 -0500, Ed Ruf <egruf_usenet@cox.net>
>>him open.
No, the Canon grip loses power sometime, flexes and power indicator is
sporadic in operation.
"John A. Stovall" <johnastovall@earthlink.net> wrote in message
news:932841dc3j1cfahlbkuirlvo3spbq8abv5@4ax.com...
>>>him open.
> "High up, Santa Ana, we're killin' your soldiers below
> So the rest of Texas will know
> And remember the Alamo."
> "Remember the Alamo"
> by Jane Bowers
I think that's just with early iterations, those who bought theirs after the
first of December don't seem to have those problems. I certainly don't.
The only problem I've had is that the AA adaptor is non functional, but I
don't need it, anyway.
On Fri, 25 Mar 2005 07:29:42 -0800, "Skip M" <shadowcatcher@cox.net>
>>>>him open.
>> by Jane Bowers
>Skip Middleton
>http://www.shadowcatcherimagery.com
I would (and do) consider that a red flag to possible other problems
with the unit. I do not feel confident to depend on any equipment (as
a pro) which does not fully function as described. Not to mention the
fact that Canon customer support and repair department is pathetic,
beyond comprehension.
>him open.
>-Winston
not sure what that 6000 sn is meaning. My sn is 6 digits starting with
02xxxx and it is a bit older and never (after 4 &^$%##&^$!!! returns
to Canon!!) has operated fully as described.
>-Winston
I have other power problems that have nothing to do with flexing and
Canon cannot fix them. Their incompetence is stunning!
>> reviews on Amazon.
>already.
A common problem that I experience and have read of others also. The
whole grip is full of bugs and glitches, some of which Canon is
clueless as how to repair!
>time.
>buy
>> it.
>the box.
>number.
Why do you say that? What exactly IS the number?
>UPC code.
>> buy it. I know, that's hard to do online, if not impossible. This
>> might be one time to give your local camera dealer some business to
>> help keep him open.
>> -Winston
Mine is "055266" and I win s/n poker so far (deuces are wild, right?).
It clamped on tight from the beginning, I can't make it flex while
mounted, and its AA insert works just fine, but not very long, as
detailed in a previous battery-grip-duration thread.
"ZONED!" <no_email@please_post.net> wrote in message
news:424444ac.567556312@newsgroups.comcast.net...
>>>>>him open.
>>>>the
>>> by Jane Bowers
>>the
>>Skip Middleton
Well, I did, too. But after 3 months of use and literally thousands of
exposures, I haven't had a single grip related problem. Not one. Not even
when I try to flex the grip to duplicate what others have done, or tried to
do. Of course, now, having said that, I've guaranteed that I'll have a
plethora of problems tomorrow! <G> (Back in Sept, I had posted that I
hadn't had a single lockup, and the next day, had 5.)
Frankly, the 20D has had us rather badly shaken, and wondering if we had
made the right choice. But having committed a great deal of money to the
project, we had no choice but to soldier on. Canon's support is pathetic,
I'll agree. Their only comment on any email I've sent them is, "send the
camera and (name your part) for evaluation." We cannot afford to have our
equipment down, and at the mercy of the vagaries of a repair department with
little incentive to achieve a quick turnaround. And every time I ask for
back up, like Canon Pro Services, I am greeted with a resounding silence.
There have been times when I've seriously regretted choosing Canon, and
having so much invested on other Canon equipment makes it difficult to
switch brands at this point. And, too, I don't see anyone with a better
product or service, having had worse problems with Minolta's customer
service and reading horror stories about Nikon's. Now, the cameras do
perform up to expectations, the flash issues are taken care of by not using
Canon flashes, the lockups seem to be a thing of the past, the grip does
what it is supposed to do.
"Frank ess" <frank@fshe2fs.com> wrote in message
news:jOidncxPVpUW9NnfRVn-hA@giganews.com...
>>> help keep him open.
>>> -Winston
> Mine is "055266" and I win s/n poker so far (deuces are wild, right?). It
> clamped on tight from the beginning, I can't make it flex while mounted,
> and its AA insert works just fine, but not very long, as detailed in a
> It came to me in mid-December.
> Frank ess
Well you have me beaten, 044862, also from December.
In message <RT51e.788$k57.60@fed1read07>
"Skip M" <shadowcatcher@cox.net> wrote:
> <SNIP>
You are [reasonably] close to the Irvine service center.
Go there in person, be reasonable, and don't take no for
an answer. The last thing they want is to have a problem
at the repair desk that services one of the largest
entertainment industry markets in the world. Photographers,
runners, couriers and industry insiders are in and out the
door all day long. Asking if they liked my software that
was running there on their machines...that may have helped
a wee bit, but it *is* the entertainment business, and
direct word of mouth advertising is everything. ;^)
"Confused" <somebody@someplace.somenet> wrote in message
news:5cs94116ot2psf54vb2he5t2tl83qkb90f@4ax.com...
>> <SNIP>
>> pathetic,
>> our
>> with
> Jeff
I would go there, in fact, I did back when I was using an A-1 (FD mount) but
I don't have time, now. Besides the wedding business, I have a pesky day
job, too, that takes up the better part of 6 days a week, and literally
don't have a day off. I get done with my day sometime around 8 or 9 on
weekdays, and have weddings or some sort of shoot on Sat. I may be able to
get a couple of hours off on an occasional Friday, but that's rare.
Today, Easter Sunday, is the only Sunday I'll take off between the end of
Feb. and the end of August.
