I am really bad at front panels hahaha.
Here is a picture of a 680i SLI boards front panel connections:
http://www.guru3d.com/imageview.php?image=9697
I have the EVGA version of that board, but its the same Front Panel.
Here are the connections I have with my case:
HDD LED (2 pin)
RESET SW (2pin)
Power SW (2 pin)
POWER LED+ (1 pin)
POWER LED- (1 pin)
The kind of anwser I'm looking from you guys is something like this:
"HDD LED plugs into green pin set" and etc;
Thanks,
Austin
HDD LED (2 pin)
RESET SW (2pin)
Power SW (2 pin)
POWER LED+ (1 pin)
POWER LED- (1 pin)
Thanks,
Austin
