Approximate Purchase Date: In the next week or so.
Budget Range: $1500
System Usage from Most to Least Important: surfing the internet, music, watching streaming video, gaming
Parts Not Required: moniter
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: intel processors
Overclocking: Maybe
SLI or Crossfire: No, unless cost effective in budget and worth it.
Monitor Resolution: 1920x1200
Additional Comments: I want cold temps.
I am passing my old build on in my family and am looking to build a new system for general use and some gaming, older games (i.e. Half-Life 2-ish stuff), but at high resolution (1920 X 1200). The old system is an E8400 with a HD4850 video card in a Rosewill mid-tower case. I have had some temperature problems in the old case especially with the video card as it gets above 100 C quickly when gaming (it will be going to a non-gaming person in my family). So, I am looking to keep temps way down if possible. I want to keep the cost at around $1500. Please let me know what you think of this proposed build...
CASE: Corsair Graphite Series 600T CC600TM Mid-Tower Gaming Case
A full tower is just too big. This case is bigger than a traditional mid-tower, so more space for cooling and the wire management looks great for a clean build, plus I think it looks good. I want something bigger than what I have and all the AZZA and Antec mid-towers are about the same size as my current case.
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Motherboard: GIGABYTE GA-Z68XP-UD3-iSSD LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
I know that the cache feature is hotly debated as to its usefulness, but the SSD on the board comes at a bit of a discount when bought with the board and as you will see I only plan to cache the HDD storage drive for limited gains.
Memory: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
HDD: Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Data storage drive.
SSD: Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
Boot drive only with some applications so 64GB should be enough.
PSU: SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD ...
Optical Drives: LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
AND
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
I like having two optical drives, one retail for the software, even though it is old, for $4 more could be worth it, if not no loss.
Video Card: SAPPHIRE Vapor-X 100314VXSR Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card ...
Powerful enough and cool, hopefully.
CPU Cooler: CORSAIR H80 (CWCH80) High Performance Liquid CPU Cooler
Looks great keeping the middle of the case open for air flow, fits the case I like, seems to keep CPU cool well in reviews.
Case Fans and Controller: 4 Rosewill RFA-120-K 120mm Case Fans
For the mesh side panel of the case, maybe one intake and 3 exhaust? I want it cold in there.
NZXT Sentry Mesh Fan Controller w/ Five 30 watts Channels
Works and matches case
If you have stuck with me this far thank you, and I appreciate your input.
