10 celcius idle temp with h100 on fx8120 real?? *Need Help*
Last response: in CPUs
Related ressources
- [WTA] Is Stock Temp for Intel I7-3930k Safe? (50~60 Celcius ) - Forum
- CPU @ 61 Celcius at idle - Forum
- Can I use a corsair h80 or h100 ? - Forum
- Is it normal for core i7 930 to idle at 55-58 celcius ? - Forum
- AMD FX-8120 Prime95 test core error - Forum
Related ressources:
- ForumRecommend an Air cooling solutoin for moderate OC's on AMD FX8120
- ForumHelp with overclocking AMD Fx-8120
- ForumAdvice with Overclocking an FX-8120
- ForumH100 compatible cases
- ForumAMD Athlon 64 3000+ @ 120Deg Celcius ! ...or is it the GPU?
- ForumUPDATED - Real temp vs Asus bios temp accuracy - NEW INFO
- ForumWhich cpu cooler (HSF/CLW/WC) is the real best for overclocking 3770K?
- ForumAMD FX-8350 45Degrees celsius Idle temps, high?
- ForumH100 as pump/rad combo for water system
- ForumAMD FX-4100 0 celcius
- ForumI5 2500k 85 deg idle cpu temp ?
- ForumCpu running at 62 degrees celcius !
- ForumPSU Help
- ForumMotherboard does not start up with processor
- ForumWhich temp is right
- More resources
