First Build, need help with power supply and others!! please help!
Hey everyone this is my build that is on order at the moment. i just need advice on whether an 750watt power supply will suffice?
~NZXT Phantom ---------------------------------------------------------------------------(CASE)
~Gigabyte GA-X58A-UD3R ---------------------------------------------------------------(MOTHERBOARD)
~Gainward GeForce GTX 560 Ti 2GB Phantom ---------------------------------------(GPU)
~G.Skill Ripjaws F3-12800CL9T-12GBRL 12GB (3x4GB) DDR3 --------------------(RAM)
~Corsair Force Series 3 60GB SSD -----------------------------------------------------(SOLID STATE)
~Samsung SpinPoint F3 1TB HD103SJ -------------------------------------------------(HDD)
~CoolerMaster V8 -------------------------------------------------------------------------(CPU COOLER)
~ASUS PCE-N13 802.11 Wireless N PCI-Express Adapter -------------------------(WIRELESS NETWORKING CARD)
~Intel Core i7 960 -------------------------------------------------------------------------(CPU)
~Logitech G110 ----------------------------------------------------------------------------(KEYBOARD)
~LG E2341V-BN 23inch LED Widescreen Monitor ------------------------------------(MONITOR)
**Corsair TX-750 V2 Power Supply**
Also i realised the i7 960 was a bad choice seeing as the new intel CPUs are much better, but ive already ordered the x58 (socket 1366) motherboard so thats what i've got. if anyone could suggest a better GPU alternative for ($320) i'm always listening..
so far i've only ordered the case, motherboard, HDD and monitor so suggestions for other then that will be greatly appreciated..
6 answers Last reply
More about first build power supply others help
  1. also the website i'm buying from is www.pccasegear.com
  2. A 750w psu will do just fine. Look at the Antec High Current Gamer 750w for $139 on pccasegear.
  3. so you prefer antec cooling over corsair? ill go that one becase its cheaper and i've heard good things about antec.shame its red though :/ blue would've been better haha
    The Corsair TX 750w is a good one also.
  5. Should have come here for advice BEFORE you bought your system.
    You would have ended up with a faster, cheaper, more upgradeable system.
  6. ^^^ I did ask for advice here mate and for what i want to run, (adobe suite) people recommended the i7 because of the hyper-threading tech, not everyone on this site wants a gaming build. but thank you for your effort.
New Build Power Supplies Systems
