Problem with sound card!
I bought a Genius SM-Live 5.1 but I just can't make it work!!
I installed everything, but on the audio control panel it says that there's no jack information of the sound card and when I try to play any music on my PC, it just don't play!! I mean, I click to play but the music doesn't foward, it just stay on 00:00 all the time!
What the hell is going on? Thanks everyone!
9 answers Last reply
More about problem sound card
  1. did you troubleshoot your pc?
  2. Yes, it didn't find any solution! =/
  3. did you reinstall and update the drivers of the soundcard before you tried it again?
  4. many and many times! =(
    Here's a print screen from what I get! Before that, it was telling the jack where my speaker was connected (but the sound wasn't working anyway), and now it doesn't even tell that! =/
  5. click on the high def speakers just above headphones and try to install that again and see what happens
  6. Sorry, but I didn't found any option to reinstall it! =/
  7. go to device manager and it should show the audio devices thats not working, With a yellow x on the audio device click on the ones with the problems and let the drivers update
  8. Ah, yes, I already reinstalled it many many times, but It still doesn't work! =/
    There's no yellow X in any device
  9. i checked and alot of people have the same problem and the only solution is to go to the website and get other drivers or go back to the Manual
Sound Cards Control Panel Music Components
