Situation is kind of odd.. never had anything happen like this. I thought my Video Card was going bad but I tested it in another machine and it works perfectly.
When I boot the computer I get strange vertical colorization that you might expect if the video card was going bad on the hardware side. Can't get into windows at all unless its in 640x480 safe mode, and even then it isn't detected as an ATI (it's a HIS IceQ Turbo 6970). I can put a card in the same slot that does not have the need for auxiliary power and it works perfectly. I tested another card that needs Aux power and I didn't even get a bios/boot screen, just black the entire time. The only thing I can think of is that the aux power cables have gone bad... does that seem reasonable or is there something else that could be causing this issue that I'm missing?
