Need advice on the system i wish to build
t4n60
14
Hi all, i am thinking of completly upgrading my system - a total overhaul, currently the spec i have is:-
CPU -AMD Athlon II X3 450 3.2GHz Triple Core Processor
M/B - Asrock M3A-UCC Socket AM3 Motherboard
RAM - Kingston 4GB DDR3 1066MHz Non-ECC 240pin DIMM Memory Module (X2 - 8gb in total).
GPU - Sparkle NVIDIA GeForce GT 430 1GB Graphics Card
HDD - 500GB Western Digital Caviar Blue 3.5" Hard Disk Drive
2TB Western Digital Caviar Green 3.5" Hard Disk Drive
DVD - uknown as was stolen from a previous pc
CASE - Tornado TO11A Mid Tower Case - Black
CPU FAN - AMD AK-861CU CPU Cooler
CASE FAN - Akasa 12cm Quiet Cool Blue Case Fan (X2)
PSU - not sure, was stolen from a previous pc
running on win 7 ultimate 64 bit
And i am thinking about replacing it with this:-
CPU - Intel CPU Core i7 2600K Unlocked Sandy Bridge Quad Core
M/B - Asus P8P67 Pro Rev3 Intel P67 Express Socket 1155 Motherboard
RAM - Corsair Memory Vengeance Black 8GB DDR3 1600 MHz CAS 9 XMP Dual Channel Desktop
GPU - Inno3D GT 430 2GB SDDR3 DVI VGA HDMI Out PCI-E Graphics Card
HDD - Western Digital Caviar Black 750GB WD7502AAEX (X2 to be raided)
DVD - LG Blu-Ray Writer, BH10LS30
CASE - Antec Lanboy Air Blue Modular Case
PSU - Thermaltake Toughpower XT 875W Modular PSU
CPU FAN - Antec Kuhler Box AMD/ Intel CPU Cooler
to be run on windows 7 64 bit home premium
any thoughts or commentss please as i am not totally sure with the newer stuff as xp was my thing - much simpler
Thanks
Andy
chillin15
387
That GPU is a major bottleneck in your system. I would downgrade to 2500k and get a better GPU. the 2600k gives no benefit in gaming (if that is what your build is for).
t4n60
14
will be doing some gaming WoW, battlefield 2142, battlefield 2 but nothing major realy.
how do you mean by bottle neck - by using so much performance, power e.t.c. going in and not much coming out?
t4n60
14
what is the difference between the i7 2600K and the i5 2500K apart from the list im the pic below?
set
t4n60
14
updated spec:
CPU - Intel Core i5 2500K 3.3GHz Socket 1155 6MB
GPU - Inno3D GT 430 1GB SDDR5 DVI VGA HDMI Out PCI-E Graphics Card
chillin15
387
I mean the GPU will be slowing down everything in your system - mostly the cpu. Are you able to afford a geforce 560 ti? Or an amd 6870?
t4n60
14
unfortunatly not, as my buget is £1000 and so far with whats on there (the second list) i am already £10 over that and still need to put a card reader on that. I dont think the amd 6870 would work anyway as i am going for an intel i5 this time (was originally going to be an i7 but that came to £1140).
or is there something i could change? use a different shop, the ones i use now are:-
www.cclonline.com
www.scan.co.uk
www.buyer.co.uk
scan and ebuyer on this build as parts that i got are cheaper on there
t4n60
14
been doing a bit more research and i think i have finaly set on a setup there will be a 2TB HDD going in from other PC
see below
michxymi
788
You said you aren't playing anything major but the pc you are planning to build is overkill. A small upgrade from your old PC seems a better choice!
michxymi
788
Check this option. Keep your old motherboard (clean it and upgrade bios) along with your old RAM (clean this too. I would give a try, but I don't know if they can work at 1333MHz with 1.65V and 9-9-9-24 timings).
Then buy a Phenom II X4 955
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
A cheap but awesome for it's price CASE
Xigmatek ASGARD II B/O CPC-T45UE-U01 Black / Orange 0.8 mm SECC / Aluminum and Aluminum Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811815006
A GTX 460. Although I would like to know your resolution, maybe it's overkill!
ZOTAC ZT-40408-10P GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500202
And a good PSU for your system
XFX Core Edition PRO450W (P1-450S-XXB9) 450W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207012
With 334$ with MIR, in my opinion you'll be more than fine!
