Lost a modular 6-pin pci-e cable, is a Y-cable the answer?
Hello All,
Long-time, first time. I saw a couple of threads regarding similar issues but wasn't able to find an answer.
In short, I have a AeroCool 750w semi modular psu. It has two 6+2 pin pci-e cables hardwired as well as two 6+2 pin pci-e modular cables.
Currently I'm running an SLi setup where my gpu's use one 6-pin each and I have been using the hardwired cables. I now want to upgrade to a SLi or CF set-up that uses two 6-pin pci-e's per gpu (GTX 560 ti's or HD 6870's). My psu is plenty for handling those GPU's, but I have lost one of my modular pci-e cables. So basically I have three 6-pin pci-e's and I need four!
Is the solution a Y-cable? If I use a Y-cable that will give me two 6-pin connections from one 6-pin pci-e, is my problem solved? Or do the cable only output a certain amount of wattage per cable (or will the gpu's draw as much as they need from one cable with a y-splitter)?
Hope that all makes sense and that you will be able to help me!
Thanks
3 answers Last reply
More about lost modular cable cable answer
  1. You have a very good psu btw if it's the Horsepower.exact same CWT design as the Corsair HX-750.
    I wish i had a definitive answer for you.but i don't unfortunately.
    I would give it a shot though if i were in your shoes.
  2. Yes it's the horsepower 750
    Your best bet is to contact AeroCool imo.
    Explain your situation.
    http://www.aerocool.us/contact.htm
Power Supplies GPUs Cable PCI Express Components
