Hey All
Im busy fixing someone's PC and multiple problems have arisen. I'll give the problem then describe in detail how i came to it.
It is a fairly old PC so please bare with me. Its for my gf's mom who uses it to play solitaire and her grandkids who do school projects and so on...
The PC specs:
AMD 64 3000 CPU
Gigabyte GA-k8vm800m MOBO
1GB DDR400 RAM (2X 512mb)
nVidia FX5200 256mb AGP Card
40Gb IDE HDD
OS: Windows XP Professional SP 2(with original MB drivers) - used to have Vista 32bit
So the problem at the moment is that when I boot up the PC, it gives me black screen with a long beep ... pause... long beep. This i know is a memory issue.
Through brute force, i've learnt that that both sticks help boot the PC perfectly when one of them is plugged in, individually, in either slot 1 or 2. That means both RAM sticks are working fine. That also means the DIMM's are both working. However when I plug both sticks in - I get the beep sequence. I've tried the same procedure with other memory modules and they work perfectly...but not together. I've tried changing BIOS settings, removing the CMOS battery for 15min...but nothing happens.
How did I get to this problem?
The PC had been working perfectly untill I opened the box to discover an enormous amount of dust inside.
I took all the components apart, and gently cleant them with an old tooth brush like I normally do with my own PC parts.
Upon putting them back together, I started encountering problems. I am now sitting with two problems left over of the 5 I had managed to fix. Namely:
- The Multiple RAM beep sequence.
- PC freezes at Windows Loading Bar with AGP card plugged in. Boots fine without it.
Any help would be highly appreciated!!
Ryan
The PC specs:
AMD 64 3000 CPU
40Gb IDE HDD
Ryan
