Laptop AC power supplies
Last response: in Laptops & Notebooks
August 11, 2005 11:15:35 PM
Archived from groups: comp.sys.laptops (More info?)
My Acer brick is marked:
AC 100-240v 1.5A
Output 19v 3.42A
I have available an IBM brick marked:
AC 100-240v 1.3A - 0.7A
Output 16v 3.36A
How critical are these power requirements? Any standards?
Any risk using the IBM brick with the Acer?
More about : laptop power supplies
Anonymous
a b D Laptop
a b ) Power supply
August 11, 2005 11:15:36 PM
"Jim" <chief_jim@go.com> wrote in message
news:V0RKe.8552$9v3.5530@fe09.lga...
> AC 100-240v 1.5A
> Output 19v 3.42A
> Output 16v 3.36A
The output voltage of the IBM brick is lower than I'd want to use with the
Acer.
Anonymous
a b D Laptop
a b ) Power supply
>AC 100-240v 1.5A
>Output 19v 3.42A
>Output 16v 3.36A
If it's 1 (one) volts output difference, I may try it, but 3 is too
much. Up to u.
If your business is looking for quick free consulting,
please ignore my replies. I only wish to reply to other
engineers/administrators and home users who are stuck
and not interested to give your business free consulting.
Thank you.
August 12, 2005 3:41:08 AM
: My Acer brick is marked:
: AC 100-240v 1.5A
: Output 19v 3.42A
: I have available an IBM brick marked:
: AC 100-240v 1.3A - 0.7A
: Output 16v 3.36A
: How critical are these power requirements? Any standards?
: Any risk using the IBM brick with the Acer?
The polarity might be different between ground and power on the two
power supplies. If the polarity is the same and it's the same
connector, you could always try it, but I'm skeptical the 16V supply
would work in a machine intended to have a 19V input.
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
August 12, 2005 9:04:29 PM
>>AC 100-240v 1.5A
>>Output 19v 3.42A
>>Output 16v 3.36A
> much. Up to u.
> Thank you.
All the responses suggest too much of a difference to be safe. I'll
stick with what I have.
Thanks all.
Anonymous
a b D Laptop
a b ) Power supply
August 13, 2005 3:23:30 AM
The difference is relatively large, and there is a very good chance that
it won't work (although I'd guess that there is also a 50% chance that
it might). But in terms of "safety", since you are proposing to use a
power supply with a lower voltage, it would be unlikely to do any damage.
Keep in mind that everything -- both power supplies and the laptop
itself -- has at least a 5% tolerance (that's nearly a volt in this
case), probably a 10% tolerance (2 volts) and possibly as much as a 20%
tolerance (4 volts). There's no way to know for sure how these
tolerances are stacking up, but the fact that the two supplies are
"nominally" 3 volts different isn't definitive. The "16 volt supply"
might put out MORE voltage than the "19 volt supply", or, on the other
hand, the real difference could be not 3 volts but 6 volts.
>>> AC 100-240v 1.5A
>>> Output 19v 3.42A
>>> Output 16v 3.36A
> Thanks all.
Anonymous
a b D Laptop
a b ) Power supply
August 13, 2005 3:23:31 AM
IME, computer supplies are pretty well regulated, so it's probably going
to put out something in the near vicinity of it's rating. If in doubt,
it's easily measured.
That said, the computer itself needs *watts*. IOW, if you supply it
with fewer volts than it wants, it's going to try to make up the
difference by drawing more amps. That's gonna make it pretty
unpredictable as to how much current the unit will draw with an
undersized supply...and what the effect of the undervoltage will be on
the computer.
To the OP: what is your issue? Is your supply kaput? If so, ebay is a
wonderful resource for laptop supplies...one of the few places where
it's hard to go wrong on computer parts there. The last time one went
south on me, I had an exact replacement within a week for less than $15.
jak
>>>> AC 100-240v 1.5A
>>>> Output 19v 3.42A
>>>> Output 16v 3.36A
>> Thanks all.
Anonymous
a b D Laptop
a b ) Power supply
August 15, 2005 5:02:19 PM
"Ian S" <iws51remove@cox.net> wrote in message
news:EKRKe.1514$091.791@lakeread06...
> > AC 100-240v 1.5A
> > Output 19v 3.42A
> > Output 16v 3.36A
> Acer.
