So i'm building a new system and i want to use a APEX PC-389-C Black Steel ATX Mid Tower Computer Case
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811154095
I want to know if the 375 watt psu of a dell xps 410 would fit in it
I'd also like to know if this ASRock N68-S UCC motherboard would fit in it.
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157202
also if the case comes with risers or do i have to buy them.
i looked at the case and it looks like it has 2 panels on 1 side would that replace the risers or do i still need them
