Project Ultra Low Buck Sub 600 build I3-21XX with monitor
belezeebub
347
My Oldest son's computer met an untimely end while I was at work I guess he tried to swap the Keyboards and now it won't power on, it isn't worth fixing so its time to consult the wise ones on a new computer
What do you think of this one?
MSI P67S-C43 (B3) ATX Intel Motherboard $104.99
Intel Core i3-2100 3.1GHz LGA 1155 65W Dual-Core Desktop Processor $124.99
Rosewill CHALLENGER Black Gaming Computer Case $49.99
ASUS 24X DVD Burner - Bulk Black SATA Model DRW-24B1ST/BLK/B/AS $19.99
Recertified: PNY GeForce GTX 460 1G RVCGGTX4601XXB Video Card $134.99
Combo Memory/PS
COOLER MASTER eXtreme Power RS600-PCARE3-US 600W Power Supply
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
$89.98
Grand Total: $524.93
kaweee
131
Should get a H61 mobo since you are using i3-2100
Here is what I would go for with $600 including monitor build(Gaming wise)
CPU:Intel Core i3-2100 Sandy Bridge 3.1GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
PSU:Antec EarthWatts Green EA-380D Green 380W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
Motherboard:MSI H61M-E33 (B3) LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130588
GPU:SAPPHIRE 100315L Radeon HD 6850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
HDD+DVD Burner:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696137
Case:Rosewill CHALLENGER Black Gaming ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
RAM:G.SKILL NS 4GB (2 x 2GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
Monitor:Acer S201HLbd Black 20" 5ms LED-Backlight
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009256
Total:$638.41 - $25 Rebate = $613.41
Edit: Forgot adding the PSU link
No to the Coolermaster PSU! It's barely a notch above junk. A quality modern PSU has full range active PFC (no little voltage switch) and some level of 80+ certification for efficiency. Seasonic, Antec, Corsair, XFX, and Enermax/LEPA are among the better brands. A single GTX460 can run on a decent 450W-500W PSU (Tom's ran one on a 380W Antec Earthwatts). On a budget, the Antec "Earthwatts" or Corsair "Builder" are good units.
belezeebub
347
Yes it will be a gaming computer and "homework" when I can get him to do it :(
I was figuring the GTX 460 1g while old can be picked up for sub-130 on Newegg and as low as 99 on sale thought it might work but I'll fiddle around with the numbers and see if I can ekk out a 6950 2gb
To be honest I use toms benchmarks and this site http://www.anandtech.com/bench/GPU11/188 sure they are synthic benchmarks but it gives me a baseline for what kind of performence I will be getting and a single 460 gtx 1g wasn't too shabby.
Here's what I would do for a $600 PC:
i5-2400: $190
AS Rock H61M/U3S3: $75
Mushkin 4 GB DDR3: $26
Seagate 500 GB: $40
Rosewill Blackbone: $37
Xigmatek 400W 80+ Bronze: $35
DVD Burner: $19
HD 6870: $175
$597.
If you need windows, drop to a HD 6850, an I3-2100, and Rosewill R102 case (saves $92, making the total $603)
