Hello,
Here are the components I'm looking at putting in my first build. In particular, I'm wondering about RAM compatibility. Any thoughts you have will be appreciated:
CPU: Core i5 2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
MoBo: ASUS P8Z68-V PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
RAM: Patriot Gamer 2 Series 8GB (2 x 4GB) SDRAM DDR3 1600 (PC3 12800) Model PGD38G1600ELK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558
PSU: Antec High Current Gamer Series HCG-750 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
GPU: Re-using old EVGA Nvidia GeForce 8800 GTS 320MB
SSD: OCZ Agility 3 60GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227725&cm_sp=DailyDeal-_-20-227-725-_-Product
or also considering: Kingston Now V100 64 GB
HDD: 2 x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Case: Still trying to figure this one out. Want it under $50, looking at NZXT's in particular.
What do you think? Will it work?
Thanks in advance!
CPU: Core i5 2500K
Thanks in advance!
