I'm almost ready to plunge for a PC upgrade, but this final detail has me stumped.
I've picked out a card, the ATI 6770 http://www.amazon.co.uk/Sapphire-11189-00-20G-6770-GDDR5-Graphics/dp/tech-data/B004XSJR5Y/ref=de_a_smtd
And this power supply seeeeeeeeeems ok http://www.amazon.co.uk/Corsair-CMPSU-430CX-Builder-Power-Supply/dp/tech-data/B0045Y1EI4/ref=de_a_smtd
But I read a review of the Corsair and it grumbled a bit about the fact that it only had one pci-e connector. I can't find a way to tell what kind of connectors the 67770 has and what it needs from the PSu.
Could somebody give me a little advice about this?
Does the psu I've picked have the right connectors? If not, what kind of specifications/cables & connectors am I looking for?
Have I even picked a suitable/strong enough psu for the card I want? I ran it through a couple of "calculators" and they gave me green lights, but I dunno you guys know best right? (Running on a core2duo with 4gb ram btw so not a hungry machine)
Thanks in advance
Thanks in advance
