Hi,
I'm at the end of my tether with this after being on Aria.co.uk's Customer Service Lines several times this morning and not getting any further with it, but just wanted to confirm that I'm not going crazy.
I've recently purchased new PC components as follows to put in my system which has a sufficient working PSU, HDD and Disk Drive:
AMD Radeon 2GB 6950 GPU
MSI 990FXA-GD65 Mobo
1866MHz Corsair Vengeance RAM
Bulldozer FX-4100 3.6GHz CPU
Now the problem is that when all the parts are in I receive no monitor signal whatsoever.
Luckily my flatmate has almost identical parts apart from his Phenom II processor, and I've managed to test my parts individually in his perfectly working system and come down to the fact that it is the processor that is at fault.
Upon turning on the PC with my Bulldozer CPU installed I receive no post beeps and absolutely no monitor signal (bearing in mind my GPU etc. all work fine in other systems).
I've requested an RMA from Aria.co.uk but had it declined this morning (24 hours after they sent the number and several hours after I posted the part back to them -.- ) on the basis that the problem was that I needed to "flash the motherboard BIOS".
Correct me if I'm wrong, but I don't believe there is a way, or at least not a safe one, of flashing a motherboard BIOS without any monitor signal at all?
This question does not take into account my fortunate situation with my flatmate having similar parts as most people wouldn't have access to such things, so with just the parts I have personally, Aria.co.uk have told me that my processor isn't faulty because I haven't flashed the BIOS, when I can't even reach that stage. Bearing in mind the 990FXA-GD65 MObo doesn't have on-board graphics.
Any help is greatly appreciated, seriously frustrated with this.
