Help with MOBO RAM compatibility
Hey, I had a previous post but for some reason i couldnt reply on it or anything so i decided to post again. Was wondering if www.newegg.com/Product/Product.aspx?Item=N82E16820145345&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_- and http://www.newegg.com/Product/Product.aspx?Item=N82E16813131781R&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_- would work. The mobo QVL doesnt specify the RAM model but very similar ones. Should it work?
1 answer Last reply
More about help mobo compatibility
  1. Yes, it'll work. QVL's are rarely all inclusive, and since it's the exact same as the black color Vengeance, it'll be just fine.
Memory RAM Compatibility Product
