Need Advice on i5 2500k/GTX560 build
Approximate Purchase Date: Ordering the parts this week.
Budget Range: $800 before rebates, but would prefer to spend about 700 ish
System Usage from Most to Least Important: Gaming
Parts Not Required: Monitor, Mouse, Keyboard
Preferred Website(s) for Parts: Newegg
Country of Origin: USA
Parts Preferences: Intel, Nvidia
Overclocking:
In the future YES
SLI or Crossfire: In the future YES
Monitor Resolution: 1920x1080
Additional Comments: Need a well rounded gaming PC that can play all current games.
Need a build that supports I5 2500K and GTX 460 Fermi 1gb.
I found this set up in New egg for $685, would love to get feedback or upgrades on any parts that would make the computer running better.
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.692056
1x Rosewill FUTURE Gaming ATX Mid Tower Computer Case,come with Four Fans-2x Front Blue LED 120mm Fan,1x Top 120mm Fan,1x Rear 120mm Fan,Support up to 7 Fans (Model:FUTURE)
$69.99
1x ASUS P8P67-M (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard (Model:P8P67-M (REV 3.0))
$129.99
1x ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (Model:ENGTX560 DCII OC/2DI)
$199.99
1x Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply (Model:BP550 Plus)
$64.99
1x Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K (Model:BX80623I52500K)
$219.99
1x Kingston HyperX X2 Grey Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model KHX1600C9D3X2K2/4GX (Model:KHX1600C9D3X2K2/4GX)
$44.99
1x Seagate Barracuda ST3500413AS 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (Model:ST3500413AS)
$39.99
18 answers Last reply
More about need advice 2500k gtx560 build
  1. http://www.microcenter.com/single_product_results.phtml?product_id=0354589
    Your welcome, you can probably find most of your items for cheaper from MicroCenter.
  2. Micro center only ships to their stores and I live in Nebraska (we don't have microcenters).
  3. bumer I am planing on same i-5 560 build and same budget and the only way i can fit is with microcenter
  4. also i don't think 550W PSu will be enough
  5. also i don't think 550W PSu will be enough
  6. You can do better for $800. That combo is missing an optical drive, so add $20 for that. The RAM is 1.65V, which is more than whats recommended for Sandy Bridge, plus it's pretty expensive for a 4GB kit (combo savings aside). That motherboard does SLI at x16/x4 which is not ideal. You can get cheaper cases.....
    CPU: Intel Core i5-2500k
    Motherboard: MSI P67A-G45 (SLI ready at x8/x8)
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
    $332.98 ($20 MIR available)
    RAM: 4GB G.Skill 1600Mhz C9 1.5V (low profile, cheap, correct voltage for Sandy Bridge)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
    $32.99
    GPU: EVGA GTX 560 Ti (more powerful than the GTX 560)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
    $239.99 ($25 MIR available)
    HDD: 500GB Seagate Barracuda
    Optical: Samsung 22x DVD Burner
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696167
    $53.48
    PSU: XFX Core Edition PRO650W (Enough power and connections for future SLI)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
    $89.99 ($10 MIR available)
    Case: Rosewill Challenger
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
    $49.99
    Total: $799.42 + $14.75 standard shipping
    Don't forget, there's $55 in available rebates...
    If that's too much, you can drop the vid card to a GTX 560 (non-Ti) or even an HD 6870.
  7. Hate to break it to u but if u plan on overclockin ur cpu(obviously) and gpu and sliing 650 is not enough. need 750
    Really?
    http://www.hardocp.com/article/2011/02/21/msi_n560gtx_ti_twin_frozr_ii_oc_sli_review/9 <--OC'd SLI 560 Tis (965/1930/1090), OC'd i7-920 @ 3.6GHz, 628 watts peak while gaming. Subtract roughly 50 watts for an overclocked i5-2500k and you're looking at around 580 watts. Figure in 80+ Bronze (85% at best) PSU efficiency, and the PSU is outputting approximately 493 watts, well under it's rated 650 watt output.
  9. i am pretty sure you suppose to take 85% from your PSU power as a 0.85*650=552 and not from the power your system is demanding. Also PSU will usually go higher under load. Just to be safe I would go for either really good 650W or 700W. Unless u sliing cfing something lower then 560ti. Anandetch reports ASUS 560ti under heavy load 310W so ther goes your PSU. Also yopu don't want to be on the edge
    $32.99
    $53.48
    $49.99
    This build is nice though
    i'd drop case for HAF 912
    ram 1300 is enough
    and get sammy f3 for a little extra
    also msi mobos have high fail rate so look into asrock or asus
    and lastly you'll need CPU cooler like hyper 212+ or scythe something something (sorry forgot) and that's extra 30
    Just like I said it's hard to fit i-5 2500k and 560ti into 800 budget especially for someone looking to spend preferably 700 don't forget taxes and shipping that will put u in 850+ also I'd rather pick parts that have no MIR as they r pain in the @rse.
    So with all that said I think we can work some recomendations for u pretty quick :)
    Rated output is rated output...that alone has nothing to do with 80+. At 85% efficiency, it means that to output 650 watts to the computer it must take in 747.5 watts from the wall. The rest is lost to heat. That XFX PSU I linked puts out 624 watts on the 12V rail alone (watts=volts*amps). Click the link below for more info.
    http://en.wikipedia.org/wiki/80_plus
    Plus I didn't suggest an ASUS card, I linked to an EVGA reference card and Anandtech has a system with an overclocked i7-920 and a reference 560 Ti pulling 352 watts loaded under Furmark, 317 watts during Crysis. As we know, Sandy Bridge takes less power than Nehalem.
    http://www.anandtech.com/bench/Product/330
    You are correct in that you don't want to be on the edge, but I don't think that 150+ watts of headroom is on the edge.
    ram 1300 is enough
    For the record, I did fit a 2500k and 560 Ti into an $800 budget, shipping and tax not included, however if he lives in a state without a Newegg distribution center, there is no tax. Rebates were not figured into the $799 total and had no bearing on the parts that I picked...they are simply a bonus if you get them back.
  13. ^ Thanks for clearing this out for me. I am actually looking at getting that combo into 800. And I have microcenter close by(kinda). So you saying I can get system with i-5 2500k 560ti and mobo for future sliing for 800? interesting.
  14. My reference shows the overclocked SLI GTX 560ti s pulling, at peak, 400W.
    http://forums.atomicmpc.com.au/index.php?showtopic=264
    Those are all calculated figures, draw from the PSU not the wall.
    The rest of the system, with moderate OC, will stay under 200W. Having said all that I still would want my PSU operating in the 60-70% range when gaming.
    My guess for gaming draw matches yours.... somewhere between 450 and 500W, mostly. 70% of 650 is 455. But an 80% draw is still pretty safe, just not ideal.
    To toss out another number though, 90% of the people who buy one card intending to add a second later.... never do. It's the speed at which GPUs progress that makes this impractical. :)
  15. I'm doing a very similar build to you and i managed to get my price down to $750. Here's my components.
    COOLER MASTER HAF 912 - $55 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    SAPPHIRE 100314-3L Radeon HD 6870 - $175 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
    Antec EarthWatts EA-650 - $55 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
    GSKILL Ripjaws X Series 4GB (2 x 2GB) - $32 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231438
    COOLER MASTER Hyper 212 Plus - $28 - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
    Seagate Barracuda + Lg Cd/Dvd combo - $68 - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696151
    I5 2500k + Msi P68 - $324 - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
    BYTECC 6 ft. 18AWG Power Cord - $5 - http://www.newegg.com/Product/Product.aspx?Item=N82E16812270406
    Exactly $750 Shipped
    Hopefully it will help you drop the price a little and get more for your money.
  16. Oh yeah? well I did a build ( on the paper) with pretty much same components plus 8Gb RAM HD 6950 and 700W PSU for 800 with shipping and taxes after 50 MIR
    so suck on that :)
    so suck on that :)
    I Dont do Mail In rebates.
  18. ^ whatever .. that's what I said 2 weeks ago. You should just go for best performance for your money // and if u can't spend extra 50 bucks on a rig // then just spend 700 or 650/ what's the point? right
New Build Systems Product
