Solved
ASUS P6X58D-E CPU Voltage Control: Manual x Offset
  • Motherboards
  • Asus
  • RAM
  • CPUs
a b V Motherboard
a b à CPUs
August 17, 2012 8:25:50 PM
Hi all,
I got this P6X58D-E mobo, but I am not familiar with all its functions.
I turned AI Tweak to Manual, to allow to set the memory frequency to 1333MHz (They are 1600MHZ standard), so I can place 6 sticks of 2GB, making it 12GB RAM.
Then in CPU Voltage Control it gives 2 options: Manual x Offset.
Which one should I set for 12GB RAM?
More about : asus p6x58d cpu voltage control manual offset
Best solution
August 17, 2012 10:44:43 PM
I have the p6x58d Premium. I have 12 gigs of mixed ram (timings very close to each other) and I have it set to xmp profile and it works fine. I don't overclock though. 6 x 2gb 7,8,7,20 at xmp half Kingston half Corsair.
Mac
a b V Motherboard
a b à CPUs
August 18, 2012 12:20:56 PM
Intel recommends caution when populating all the slots, and/or with 12GB RAM on a X58 platform. XMP is to be used with 6GB only, otherwise the integrated memory controller may not handle the extra load. That´s why I always downclock the ram frequency with 12GB. You should do the same.
m
l
August 20, 2012 2:29:41 AM
well I am running fine so won't change anything at this moment.
Mac
m
l
a b V Motherboard
a b à CPUs
August 27, 2012 3:16:12 AM
I set it to offset, and solved it by myself.
Thank you for your reply anyway.
m
l
a b V Motherboard
a b à CPUs
August 27, 2012 3:18:12 AM
Best answer selected by jemm.
m
l
