Xclio Windtunnel Problem?
One of my 2 side fans (the one farther back) won't run at a high speed like the front one does. I think it has to do with a voltage problem since they're both ran through 1 wire, instead of 1 connection per fan.
I've read about other people with fan problems but I don't have any sort of noise coming from it, it's just way slower.
I've pulled out the fan area (where the fans sit) and checked all through it. Cleaned it, moved some wires, and still same speeds.
Help?
2 answers Last reply
More about xclio windtunnel problem
  1. perhaps its a different fan with a slower max rpm?
  2. They're the same fans. I'd hope they didn't get that cheap with it as to put in a cheaper fan. Do other 250mm fans even exist? If so, I could maybe replace them?
Power Supplies Connection Fan Components
