Does the power supplies matters?
  • New Build
  • Power Supplies
  • Sapphire
  • Systems
  • Product
Last response: in Systems
August 19, 2011 6:59:53 AM
Hello,I just bought a new system AMD X6 1055T/ASUS M4A88T-V EVO/Sapphire Radeon 6950/16GB GDDR5 and I want to know if I need a better Power supply,cause I didin't bought one,and I'm attending to use the older one,wich was a cheap one.Does it matter if is older or not?
More about : power supplies matters
August 19, 2011 7:05:26 AM
16GB GDDR5? Wow, I'd like to get my hands on that. Any who, the answer to your question is yes, you got some expensive equipment you just bought, so you are going to want to get a nice, 80+ approved power supply. I would recommend something along the lines of this;
Do not skimp out on your power supply, it is very important!
August 19, 2011 7:16:47 AM
I understand.Thank you!So if I can't get that fast a better Power supply,is anything wrong if I'll use the old one?
a b ) Power supply
August 19, 2011 1:55:07 PM
You did not specify what PSU you have, But if it is a cheapee, it's probably a "piss" poor quality. Most of them will only handle 50-> 60% of rated load and that is taking a chance that it does not implode taking out your other "New" components.
August 19, 2011 4:35:36 PM
It's a Delux 600V or something.And also I've just tried to assamble all components and suprise nothing shows on monitor.I attend to believe that the problem is the compatibility between MotherBoard and Ram Mem.RAM has 1600GHZ and on Motherboard says 1333/1066 and 2000 OverClock and also the Power supply.I'm right?
a b ) Power supply
August 19, 2011 5:24:10 PM
Most ram will default to the 1333 speed and you have to tell it to run at its rated speed, at least on Intel systems.
Not a AMD guy, but I've heard that some AMD systems have a problem with higher than 1600 and a few with 1600. But again on a new installation it should default to the "spec" of 1066 or 1333.
I could label manure as "delux"mauure, but it will not smell like a rose, still smells like SXXX - You know what (LOL) Myself for PSU, may skimp on other parts but not this one, I look for a "Brand" name that has a review that indicates it is in the top 2 tiers (tier 1's normally to expensive for me).
a b ) Power supply
August 19, 2011 5:42:22 PM
No - do not do that, just my opinion, take for what's worth. Don't think anyone has ever mention that about my post's, but always a first
I could be all wet so if you have a review on his PSU that states otherwise, I'll stand corrected.
August 19, 2011 6:13:48 PM
So in other words Asus M48ATD with vengeance Corsair 4x4gb ddr3 1600 MHz with sapphire 6950 Radeon hd with AMD x6 Phenom || 1055T and with a presumptive psi 800v or more are all those together perfect compatible?than you in advance.
August 19, 2011 6:27:57 PM
Get a Corsair, Antec, XFX, or Seasonic power supply. 500 watts is more than enough if you aren't going to Crossfire. If you plan on adding another 6950 down the road, then a 650+ watt unit is recommended.
August 19, 2011 7:08:51 PM
My bad, should have quoted the first post, didn't mean to made it seem like that was to you. :??:
Was more of a bad joke, the "does power supply really matter" seemed to me rather low amounts of research or a troll attempt. I found out very quickly when I started researching that PSU is a very important part of your system.
August 19, 2011 7:10:23 PM
I went corsair TX850. Way overkill for my system, but I now have lots of headroom for upgrades and it's also now more future-proof. Was originally going for the TX750, but was able to get the TX850 for just $10 more.
