I have a Gateway laptop that is about 4-5 years old that simply will not boot up. No POST or beeps, just a black screen and LEDs. I figured the easiest thing to test would be the RAM. So I began taking the RAM out of slot 2 and left in the RAM in slot 1. The computer booted, what a sigh of relief. I thought it must be bad RAM so to be sure I switched up both sticks placing each one by themselves in each slot. Finding out both sticks actually worked, it was the 2nd SODIMM slot that was not working. I could live with just one stick of RAM to save up for another laptop. I left the laptop alone and came back to it the next day. I used the one of the two sticks of RAM in the only working slot and booted up the laptop. Nothing came up again. I also tested both stick of RAM in a working laptop so I know that these stick absolutely are fine.
The question is would you guys think that the other SODIMM slot fried on the motherboard or would this be a totally different problem than the motherboard?
Fan spins, optical drive comes on, and the hard drive works as well.
Hopefully you guys agree with me when I say I believe that the motherboard is done with. If it is, anyone know what excellent laptop part vendors. As far as I can see, Newegg and Tigerdirect deal mostly with desktop parts.
