First PC build, need help.
Bucketdeth
I am new around here and I'm not ever sure if this is in the right place but I have been looking for the past week and have come up with this build. I am from Canada so I order from Tigerdirect.ca instead of Newegg.com, and is the reason why the prices are in Canadian.
This is a budget gaming PC for under $800 (Canadian), any input would be great, thanks!
wathman
853
Looks fine, if you could find a 4GB memory kit with lower latency for a similar price I would suggest that, but if there aren't any deals on better performing RAM you may as well go with 8GB.
