Will these two different sets of Kingston RAM work together?
I currently have 16GBs of Kingston HyperX RAM. The exact model number is KHX1600C9D3K2/8G. I am giving two of my sticks to someone because they need to upgrade. I want to buy 16 more gigabytes of Kingston RAM, but it isn't the exact same model. It is Kingston HyperX Blu KHX1600C10D3B1K2/16G. Will these work together. I have a Memory OK button my motherboard, so I don't see why they shouldn't work. Just want to verify.
3 answers Last reply
More about will sets kingston work together
  1. these are the specs of both memory not working at the same cas so you will have to set them manualy or put the new one first in so they will work at the lower cas also the new one is made of 512 and the old of 256 module power requirements is not the same and refresh rate also http://www.kingston.com/datasheets/KHX1600C9D3K2_8GX.pdf the other http://www.kingston.com/datasheets/KHX1600C10D3B1K2_16G.pdf
    Since it would be a pain to get them to work together, do you think you could recommend some RAM that will work well with my original 8GBs?
  3. i would suggest buying the same kit as the 8 gig how much does your motherboard could support and do you realy need more
Memory RAM Kingston
