Closed
Sapphire ATI Radeon 6790 Dual DVI Won't Work
  • Graphics Cards
  • DVI
  • Sapphire
  • Radeon
  • Graphics
June 17, 2011 9:50:22 PM
As you can guess by the title I just bought a Sapphire Radeon 6790. It has 4 ports on the back. 2 x DVI, 1 x HDMI and 1 x Display Port. I had an XFX nVidia GTX 260 running dual DVI however dual DVI will not work on the 6790. I've gone through all the settings and removed/re-installed the display drivers. The second monitor is not present in Device Manager. Any thoughts?
More about : sapphire ati radeon 6790 dual dvi work
July 1, 2011 6:41:27 PM
Hi!
I'm having the same problem with this card, will go buy a DisplayPort->DVI cable tomorrow and see if that works instead..
Score
July 1, 2011 9:05:48 PM
Solved! :bounce:
got a spare DVI->DVI cable from a friend, and with a little trial and error got dual displays up and running. Apparently, the lower port next to the grill does not accept a VGA adapter, so my DVI cable went there, while an adapter+VGA cable goes to the top, port.
Score
