Fix limited or connectivity status of my wireless connection
Hello,
hi
can you help me with my problem
in my pc
1 answer Last reply
More about limited connectivity status wireless connection
  1. You should try to optimise your reception and avoid interference.
    1) raise the router above furniture level
    2) Experiment with channels (some will work better or worse depending on your environment)
    3) If you can detect strong neighbouring wifi, use a channel 5 stops away from strongest.
    4) Relocate cordless phone base or video sender etc.
    5) Be prepared to move the computer (or at least turn it so your body is not between the router signal and the wireless adapter's antenna.
Connectivity Wireless Connection Wireless Networking
