hmm, ok, looks like i may need to invest in a new motherboard, Any particular brand/type i should get,
Specs,
CPU-Z TXT Report
Binaries
CPU-Z version 1.57.1
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 2 (max 2)
Name Intel Pentium 4 640
Codename Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.20GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID F.4.A
Extended CPUID F.4
Core Stepping R0
Technology 90 nm
Core Speed 3199.5 MHz
Multiplier x FSB 16.0 x 200.0 MHz
Rated Bus speed 799.9 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, EM64T
L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 14.0x - 16.0x
VID range 1.116 V - 1.420 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001003h
Max CPUID level 00000005h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 16 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 1, T, 12 KB, 2 thread(s)
CPUID
0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F4A 0x00020800 0x0000649D 0xBFEBFBFF
0x00000002 0x605B5001 0x00000000 0x00000000 0x007D7040
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00004121 0x01C0003F 0x0000001F 0x00000000
0x00000004 0x00004143 0x01C0103F 0x000007FF 0x00000000
0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100000
0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020
0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75
0x80000004 0x20342029 0x20555043 0x30322E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x08006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x00000017 0x00120000 0x00000000
MSR 0x0000002C 0x00000000 0x10120410
MSR 0x000001A0 0x00000000 0x22A70081
MSR 0x00000198 0x0000102D 0x0000102D
MSR 0x00000199 0x00000000 0x0000102D
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01001003h
CPUID
0x00000001 0x00000F4A 0x01020800 0x0000649D 0xBFEBFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
Chipset
Northbridge ATI RS400/RC400/RC410 rev. 01
Southbridge ATI SB400 rev. 80
Memory Type DDR2
Memory Size 1536 MBytes
Channels Single
Memory Frequency 266.5 MHz ()
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (0000000000000000)
Size 512 MBytes
Max bandwidth PC2-4300 (266 MHz)
Part number
Number of banks 1
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-4-4-12-16 @ 266 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Manufacturer (ID) Kingston (7F98000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number
Serial number 8F200386
Manufacturing date Week 11/Year 10
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 08 0E 0A 60 40 00 05 3D 50 00 82 08 00 00
10 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80
20 25 37 10 22 3C 1E 1E 00 00 3C 69 80 1E 28 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 B5
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
00 80 08 08 0E 0A 00 40 00 05 30 45 00 82 08 00 00
10 0C 08 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 01
20 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 B2
40 7F 98 00 00 00 00 00 00 05 20 20 20 20 20 20 20
50 20 20 20 20 20 20 20 20 20 20 20 00 00 0A 0B 8F
60 20 03 86 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 39 39 30 35 34 33 31 2D 30 31 38 2E 41 30 30 4C
Monitoring
Mainboard Model RC4107MA-RS2H (0x0000033B - 0x7BC80C88)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8712
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8712
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 12 08 C0 00 C8 E3 BF 01 20 A8 00 02 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0228
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.36 Volts [0x55] (CPU VCORE)
Voltage 1 1.89 Volts [0x76] (VIN1)
Voltage 2 3.31 Volts [0xCF] (+3.3V)
Voltage 4 11.90 Volts [0xBA] (+12V)
Voltage 5 -12.16 Volts [0xBE] (-12V)
Voltage 6 -7.10 Volts [0x6F] (-5V)
Voltage 7 4.97 Volts [0xB9] (+5V VCCH)
Voltage 8 1.04 Volts [0x41] (VBAT)
Temperature 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature 1 76°C (168°F) [0x4C] (TMPIN1)
Temperature 2 3°C (37°F) [0x3] (TMPIN2)
Fan 0 2377 RPM [0x47] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 11 12 6A 00 00 00 00 00 00 80 53 7B 00 47 FF FF
10 FE FE FF 70 D7 00 00 00 00 FF FF FF FF FF FF FF
20 55 76 CF FF BA BE 6F B9 41 2B 4D 03 F8 B2 B2 B2
30 FF 00 69 50 EC AE CC A7 DA 9C 54 24 55 41 CC A7
40 7E 00 7E 7F 7E 00 FF FF 2D FF FF FF FF FF FF FF
50 FF 2A 7F 7F 7F 00 5D 68 90 5D FE 12 04 F8 08 05
60 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
70 7F 7F 7F 00 00 7F FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 FF FF FF FF 00 00 FF 0A 02 00 99 99
90 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 40°C (103°F) [0xC3C] (THRM)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A33
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xF4000000
Address 1 (memory) 0xFDFFF000
Address 3 (memory) 0xE0000000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class AGP
Caps offset 0xA0
Caps version 2.0
Caps status disabled
Max transfer 4x
Queue lenght 3 (max 16)
PCI registers
00 02 10 33 5A 06 00 30 22 01 00 00 06 00 40 00 00
10 08 00 00 F4 00 F0 FF FD 00 00 00 00 04 00 00 E0
20 00 00 00 00 00 00 00 00 00 00 00 00 5B 10 81 0C
30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
40 09 02 11 60 58 50 45 05 00 00 00 00 42 70 04 00
50 5B 10 81 0C 00 29 00 00 00 10 11 11 03 00 33 33
60 7F 00 00 00 00 00 00 00 00 0A 27 00 63 01 0B A5
70 00 01 20 20 84 84 84 84 84 40 00 08 85 43 32 18
80 00 00 00 00 94 14 00 00 30 00 20 00 02 21 00 C0
90 00 00 00 3C 88 0E 1D 02 00 00 0F 01 C3 8E 00 18
A0 02 00 20 00 17 02 00 0F 00 00 00 00 00 00 00 00
B0 00 02 00 00 30 0F 00 00 00 00 00 00 00 00 00 00
D0 2B FF 0F 00 2B FF 4F 00 04 20 B0 38 C0 02 B0 19
E0 65 00 00 00 00 00 00 00 1D 00 00 00 3C 73 03 1F
F0 03 00 09 00 00 80 80 00 03 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A3F
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x63
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A3F
PCI capability
Caps class AGP
Caps offset 0x80
Caps version 2.0
Max transfer 4x
PCI registers
00 02 10 3F 5A 07 00 30 02 00 00 04 06 00 63 01 00
10 08 00 00 F4 00 00 00 00 00 01 01 44 E1 E1 20 22
20 E0 FD E0 FD 00 D8 F0 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 B0 00 00 00 00 00 00 00 FF 00 0A 00
40 00 00 00 C0 00 00 00 00 00 00 00 00 02 10 3F 5A
80 02 00 20 00 17 02 00 0F 00 00 00 00 00 00 00 00
90 00 02 00 00 30 0F 00 00 00 00 00 00 00 00 00 00
B0 0D 80 00 00 02 10 3F 5A 00 00 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x437A
Revision ID 0x80
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x01
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000FF00
Address 1 (port) 0x0000FE00
Address 2 (port) 0x0000FD00
Address 3 (port) 0x0000FC00
Address 4 (port) 0x0000FB00
Address 5 (memory) 0xFDFFE000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x60
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x50
PCI registers
00 02 10 7A 43 07 00 B0 02 80 8F 01 01 01 40 00 00
10 01 FF 00 00 01 FE 00 00 01 FD 00 00 01 FC 00 00
20 01 FB 00 00 00 E0 FF FD 00 00 00 00 5B 10 81 0C
30 00 00 00 00 60 00 00 00 00 00 00 00 17 01 00 00
40 08 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00
50 05 00 00 00 00 00 00 00 00 00 00 00 0E FF 00 00
60 01 50 22 06 00 40 00 64 02 10 00 00 00 00 00 00
80 22 00 00 00 22 00 00 00 00 00 01 00 21 41 85 C3
A0 01 21 15 65 DD 62 DD 62 92 43 92 43 09 40 09 40
B0 01 21 15 65 DD 62 DD 62 92 43 92 43 09 40 09 40
Location bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4379
Revision ID 0x80
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x01
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000FA00
Address 1 (port) 0x0000F900
Address 2 (port) 0x0000F800
Address 3 (port) 0x0000F700
Address 4 (port) 0x0000F600
Address 5 (memory) 0xFDFFD000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI capability
Caps offset 0x50
PCI registers
00 02 10 79 43 07 00 B0 02 80 8F 01 01 01 40 00 00
10 01 FA 00 00 01 F9 00 00 01 F8 00 00 01 F7 00 00
20 01 F6 00 00 00 D0 FF FD 00 00 00 00 5B 10 81 0C
30 00 00 00 00 60 00 00 00 00 00 00 00 16 01 00 00
40 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 05 00 00 00 00 00 00 00 00 00 00 00 0E 60 00 00
70 00 00 00 00 00 60 3F 3B 00 00 00 00 00 00 00 00
80 22 00 00 00 22 00 00 00 00 00 01 00 60 20 88 02
Description USB Controller (OHCI)
Location bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4374
Revision ID 0x80
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xFDFFC000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0xD0
PCI registers
00 02 10 74 43 06 00 B0 02 80 10 03 0C 01 40 80 00
10 00 C0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 D0 00 00 00 00 00 00 00 13 01 00 00
40 80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
50 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4375
Revision ID 0x80
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDFFB000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0xD0
PCI registers
00 02 10 75 43 06 00 B0 02 80 10 03 0C 01 40 00 00
10 00 B0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
50 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4373
Revision ID 0x80
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDFFA000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0xDC
Caps version 1.1
PCI capability
Caps offset 0xD0
PCI registers
00 02 10 73 43 06 00 B0 02 80 20 03 0C 01 40 00 00
10 00 A0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 DC 00 00 00 00 00 00 00 13 01 00 00
50 02 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 20 20 00 00 00 20 00 00 00 20 00 00 00 20 00 00
70 00 20 00 00 00 20 00 00 00 20 00 00 00 20 00 00
80 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 01 01 00 00 00 E0 00 00 00 00 00 00 00 00
D0 05 00 00 00 00 00 00 00 00 00 00 00 01 D0 02 7E
E0 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4372
Revision ID 0x82
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000500
Address 1 (memory) 0xFDFF9000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 72 43 03 04 20 02 82 00 05 0C 00 00 80 00
10 01 05 00 00 00 90 FF FD 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 D4 B1 00 00 00 00 00 00 0F FF 00 00 00 00 00 00
50 FF 03 00 00 FF 01 00 00 00 00 00 00 00 00 00 00
60 01 00 03 06 BF BB DE 8F 00 90 00 00 20 00 00 00
70 00 01 00 00 08 00 C0 FE FF 4E 00 00 00 00 00 00
80 0F 0A 00 00 00 00 00 00 00 00 00 00 00 70 DD 3A
90 01 05 00 00 F8 CE FF 00 00 00 00 00 00 00 00 00
A0 00 00 FF FF FF FF 00 00 03 3C 2B 00 D0 7B 00 F9
B0 05 00 02 A8 00 00 00 00 00 00 00 00 F0 0F 13 01
C0 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 D8 0C 00 00 00 41 00 00 00 00 00 00 55 00 00 01
Location bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4376
Revision ID 0x80
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 4 (port) 0x0000F400
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0xFF
Int. Pin 0x01
PCI capability
Caps offset 0x70
PCI registers
00 02 10 76 43 05 00 30 02 80 8A 01 01 00 40 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 01 F4 00 00 00 00 00 00 00 00 00 00 5B 10 81 0C
30 00 00 00 00 70 00 00 00 00 00 00 00 FF 01 00 00
40 99 20 20 99 FF FF FF FF 00 00 04 40 00 00 00 00
50 00 00 00 00 09 00 05 20 00 00 00 00 00 00 00 00
60 00 00 40 01 10 2C 46 18 01 00 00 00 FF 03 00 00
70 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x4377
Revision ID 0x80
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 77 43 0F 00 20 02 80 00 01 06 00 00 80 00
40 04 00 00 00 FF FF FF FC BF FF 00 00 00 00 00 00
60 00 00 00 00 00 47 00 00 0E 00 0F 00 F8 FF FF FF
70 67 45 23 01 00 00 00 00 00 00 00 00 01 00 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x4371
Revision ID 0x80
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 71 43 07 05 A0 02 80 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 02 02 40 D1 D1 80 22
20 D0 FD D0 FD C0 FD C0 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00
40 26 00 3C FF 00 00 00 00 04 01 3F F1 00 00 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Audio device
Location bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
Vendor ID 0x1002
Model ID 0x4370
Revision ID 0x80
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x01
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xFDFF8000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x40
PCI registers
00 02 10 70 43 06 00 30 04 80 00 01 04 01 40 80 00
10 00 80 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 02 02 00
40 05 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A61
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x01
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xD8000000
Address 1 (port) 0x0000EE00
Address 2 (memory) 0xFDEF0000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps class AGP
Caps offset 0x58
Caps version 3.0
Max transfer 8x
Queue lenght 1 (max 256)
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x80
PCI registers
00 02 10 61 5A 07 00 B0 02 00 00 00 03 01 40 00 00
10 08 00 00 D8 01 EE 00 00 00 00 EF FD 00 00 00 00
30 00 00 00 00 58 00 00 00 00 00 00 00 11 01 08 00
40 00 00 00 00 00 00 00 00 00 00 00 00 5B 10 81 0C
50 01 80 02 06 00 00 00 00 02 50 30 00 3B 1E 00 FF
60 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 2 (0x02), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Address 1 (memory) 0xFDDFF000
Subvendor ID 0x105B
Subsystem ID 0x0C81
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 EC 10 39 81 07 00 90 02 10 00 00 02 00 40 00 00
10 01 DC 00 00 00 F0 DF FD 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 20 40
50 01 00 C2 F7 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 09/05/2006
DMI System Information
manufacturer DIXONSXP
product Ei 314
version unknown
serial 910300800600N364627409
UUID {62581500-204F-0620-1116-083937000000}
DMI Baseboard
vendor DIXONSXP
model RC4107MA-RS2H
revision unknown
serial UYCF64413320
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) 4 CPU
clock speed 3200.0 MHz
FSB speed 200.0 MHz
multiplier 16.0x
DMI Processor
manufacturer Intel
FSB speed 200.0 MHz
multiplier 16.0x
DMI Memory Controller
correction unknown
Max module size 32 MBytes
DMI Memory Module
designation A0
size 512 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Port Connector
designation USB1 (external)
port type USB
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (external)
port type USB
DMI Extension Slot
designation PCI0
type A5
width 32 bits
populated yes
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
DMI Memory Device
designation A3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API ATI I/O
Display Adapters
Display adapter 0
Memory size 64 MB
GPU ref clock 27000
PCI device bus 1 (0x1), device 5 (0x5), function 0 (0x0)
Vendor ID 0x1002 (0x105B)
Model ID 0x5A61 (0x0C81)
Performance Level 0
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 11.0
