Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > First Boot Problem- light/fans shut off in half second
Forum Systems : New Build First Boot Problem- light/fans shut off in half second
Hey so I helped my roomie out with his first build. We got it all in the case and pressed the power button. We got a flash of light from the PSU (which has a big blue light in it) and some noises from the fans and then it all shut down. No beeps, no video, no anything. We pressed the power button again and the second time didn't even get the flash of light and fan activity.
The parts are as follows:
Mobo: ASRock P67 PRO3 (B3)
CPU: Intel i3 2120
GPU: XFX Radeon HD 6870 1GB
PSU: Raidmax 630W pseudomodular
RAM: G.SKILL Sniper 8GB (2 x 4GB) DDR3 1333
HDD: seagate barracuda SATA 6 GB/s 500GB
Optical: samsung Blu-ray SATA burner
So we opened the case and checked all the power connections and RAM to make sure it was in. Then we fired it up again while the case was open. This time we saw the power supply lights turn on and the PSU fan and CPU fan start to rev up (which we assume happened the inital try but just didn't get to see it). However it only got power for about a half a second and then it all shut down.
I'd normally try a different PSU in the build but I have no other PSU that can power the build with it's connections. Any ideas? Should I try to take something out to rev it up? Like run with less parts or something. (the GPU is needed for video output)
I've got no idea which part is the culprit as I've never seen the PSU give power to only shut off before. In my experience when the PSU gives out it never gives any sign of life on boot. My only idea is maybe the Power switch header is connected backwards, but would it cause this pattern of behavior? Any help is appreciated, thanks. If the RAM was bad would it give me some mobo beeps? if the CPU is bad it would too right?
Help is appreciated oh wise ones!
Reply to hialeah05
Sounds like you might possibly have a shorting problem. Is there by any chance a MB standoff under the MB that is not located under a mounting hole in the MB?
Reply to abekl
hmmm, you know I actually do have another MB mounting screw under the Mobo that never lined up with the MB mounting holes. It is still down there and very possibly causing a short. It never crossed my mind until you just now mentioned it!
I'll try to see if I can unmount it today. Thanks, I'll let ya know what happens
Reply to hialeah05
I'm having this exact same problem. Power for a split second then nothing. I'll look for a short.
Edit: Its because I never plugged the CPU plug in lol
Message edited by DannyITR on 01-07-2012 at 04:43:52 AM
Reply to DannyITR
So the issue was....the GPU had the wrong power plug in it. My roommate whose comp it was realized that there were two identical plugs and the wrong one was plugged into the GPU.
I assume the incorrect power lead had the wrong voltage/current specs to run the mammoth card...
Reply to hialeah05
There are 1807 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 1 hour ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
