[Help] Computer wont Power on!!!
Hey, my computer doesnt want to power on for some reason, it shut down suddenly yesterday and after that it wont power on. The power light on thr power button at the front comes on once i press it, the cpu fan and psu fan spins for a second or less and then everything just stops, no beep sound, and the power light at the front eventually turns off. I've recently replaced my PSU so its brand new (used it for 3 days) because my old one has died so maybe I got a bad one sent to me. Any ideas what it could be?
Specs:
Win 7 64bit
2.3GHz Intel 2 Duo CPU
Intel bearlake g31/g33
GeForce 9600GT
2 x 2 GB OCZ DDR2 800Mhz ram
650w Cooler Master PSU
Barracuda 7200.10 320GB HDD
3 answers Last reply
More about help computer wont power
  1. My first guess would be your power supply. CoolerMaster does not have a particularly good reputation with power supplies.
    Part of my standard troubleshooting reply:
    The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
    I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
    Breadboard - that will help isolate any kind of case problem you might have.
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
    Make sure you plug the CPU power cable in. The system will not boot without it.
    I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
    You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
    If no beeps:
    Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
    At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
    The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
    You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
    http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
    A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
    This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
    If the system beeps:
    If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
    Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
    Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
    At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
    Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
  2. I've tried using paper clip to connect the green pin to black, and power on the PSU - the fans were spinning continuosly without problems so I guess the PSU isnt dead. What do you mean by connecting everything and running the same test?Plug in the components etc?
  3. Tried another 550w psu from another system, computer powered on just fine... i guess its a dodgy psu.
    I'm gonna get a different brand PSU, what would you recommend?
    What do you guys think of this: OCZ ZS Series 650W 80+ Bronze PSU with 135mm Fan & single +12V Rail
    http://www.ebuyer.com/264511-ocz-zs-series-650w-80-bronze-psu-with-135mm-fan-single-ocz-zs650w-uk
Power Supplies Computers Power Components
