3 monitor setup help?
hey everyone. just wondering, with an ati 5770hd gpu & win 7, can u run 3 monitors?
details: my htpc is setup in living room (1 hdtv). then i have a 2d monitor hooked up in office frm same pc runig in clone mode. i would like to add a 3rd monitor (2nd in office for dual display)but to run those 2 in expand/strech mode.
Is this at all possible with 1 video card that has 1 hdmi and 2 dvi ports. anyone know?
just to clarify monitor 1 & 2 = clone; while monitor 3 is a stretch/expand of 2.
1 answer Last reply
More about monitor setup help
  1. My Gigabyte HD5770SO allows three displays with DVI, DP and HDMI. That requires an active DP to DVI adapter, such as this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814999032
    As far as I know, none of the 5770s allow 2 DVI + HDMI for a tri monitor set-up. Double check your cards manual for allowable connections.
Radeon Monitors Office Graphics Product
