Does a zalman cooler 9900 have an auto fan/ or manual
is the fan control automatic and adjusts to my needs based on what I am doing
or Do I have to manually turn up the fan ??
1 answer Last reply
More about does zalman cooler 9900 auto manual
  1. its pwm fan, controlled by the motherboard basically but there is a device/cable that comes with it that drops the speed about 25% if you install it. Otherwise the max speed is about 2k and a bit noisey. With it its about 1500rpm and does much better.
CPUs Zalman Cooling Fan Fan Controller
